- From: Jean-Christophe Filliatre <Jean-Christophe.Filliatre AT lri.fr>
- To: Thery Laurent <thery AT ns.di.univaq.it>
- Cc: dehlinge AT dpt-info.u-strasbg.fr, coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Re: trying to use Init.Wf.Fix .
- Date: Fri, 7 May 2004 09:49:44 +0200
Thery Laurent writes:
> if having a clean extraction is important, the usual trick to get
> simplification back is to use rewriting.
> For this, one way to go is to first define a predicate R with the idea
> that n R m means m = f(n), and shows that it is injective.
It is indeed a nice solution and it gives the expected extraction, namely:
let rec f x =
match eq_nat_dec x (S O) with
| Left -> O
| Right ->
(match even_odd_dec x with
| Left -> f (plus x (S O))
| Right -> f (minus x (S (S (S O)))))
However you get exactly the same extraction from a direct use of
well_founded_induction, since there is an obvious variant for function
f:
Require Omega.
Require Export Even.
Require Export Peano_dec.
Require Export Wf_nat.
Definition variant (n:nat) : nat := if even_odd_dec n then n+2 else n.
Definition f : nat -> nat.
refine
(well_founded_induction (well_founded_ltof _ variant) (fun _ => nat)
(fun x frec => if eq_nat_dec x 1 then 0
else if even_odd_dec x then frec (x+1) _
else frec (x-3) _));
unfold variant,ltof;
case (even_odd_dec x);
case (even_odd_dec (x+1));
case (even_odd_dec (x-3));
intuition;
try solve [elim (not_even_and_odd (x+1)); auto with arith];
(assert (x=0 \/ x=1 \/ x=2 \/ x >= 3); [ omega | intuition ]);
subst; inversion_clear o.
inversion_clear H; inversion_clear H0.
Defined.
Note the use of the `refine' tactic which is precisely given the
expected program, as a reminiscence of the Program tactic.
Hope this helps,
Jean-Christophe
- [Coq-Club] Re: trying to use Init.Wf.Fix ., dehlinge
- Re: [Coq-Club] Re: trying to use Init.Wf.Fix .,
Thery Laurent
- Re: [Coq-Club] Re: trying to use Init.Wf.Fix ., Jean-Christophe Filliatre
- Re: [Coq-Club] Re: trying to use Init.Wf.Fix ., Thery Laurent
Thery Laurent
