- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] Some problems with modules.
- Date: Wed, 19 May 2004 17:27:37 +0200
I'm working on a big project in Coq 8.0 and I really appreciate all its new
features, including module system (which is not new to Coq 8.0 but is new for me). But I have ran kind of too many times into problems with them. I hope that's just because I'm not experienced with modules and some more experienced users can help me figure out what I'm doing wrong. Below are my 3 module-related problems. If anyone can help me with any of them (especially 1st one) I'll be really grateful! And although the examples are very artificial (to make them short and readable) in case of every presented problem I run into it in course of my development and it caused my some trouble.
(1) Below is a structure of my modules simplified and without a content. My problem is to make Coq unify between modules H.T and Comp.T (which are clearly the same) in module HorpoWF. Basically I won't to get rid of an error message that appears when trying to enter definition for HorpoWF.x. Note that in case Term is just a definition (not an inductive one) everything works fine.
> Module Type Signature.
> Parameter A: Set.
> End Signature.
> Module Terms (S: Signature).
> Inductive Term: Set :=
> | blah: Term.
> End Terms.
> Module Horpo (S: Signature).
> Module T := Terms S.
> End Horpo.
> Module Computability (S: Signature).
> End Computability.
> Module HorpoWF (S: Signature).
> Module H := Horpo S.
> Module Comp := Computability S.
> Variable a: H.T.Term.
> Variable b: Comp.T.Term.
> Definition x := a = b. (* ERROR! *)
> (* The term "b" has type "Comp.T.Term" while it is *)
> (* expected to have type "H.T.Term" *)
> End HorpoWF.
(2) Let's say we have a hierarchy of modules one being refinement of another. For instance modules describing order with more and more assumptions about it. Below I'll restrict to two modules but in principle there can be much more.
I can see two methods (at least) of such definition.
> Module Type Relation.
> Parameter A: Set.
> Parameter R: A -> A -> Prop.
> End Relation.
> Module Type Order.
> Parameter A: Set.
> Declare Module R: Relation with Definition A := A.
> Parameter R_irr: forall (a: A), ~R.R a a.
> End Order.
or
> Module Type Relation'.
> Parameter A: Set.
> End Relation'.
> Module Type Order'.
> Declare Module R: Relation.
> Parameter R_irr: forall (a: R.A), ~R.R a a.
> End Order'.
Both approaches have disadvantages. It is possible to avoid them?
For the first one let's imagine a functor that takes as argument a module representing relation and another one representing it's extension to an order. One would like to write:
> Module Test (R: Relation)(O: Order with Module R := R).
which of course is not accepted by Coq (Signature components for label A do not match)
For second one imagine that we want a functor with order over given set as argument.
> Module Type X.
> Parameter A: Set.
> End X.
As Coq doesn't allow even on syntax level to write:
> Module Test (S: X) (O: Order' with Definition R.A := S.A).
The only solution I can see is to write:
> Module Test (S: X)(R: Relation' with Definition A := S.A)
> (O: Order' with Module R := R).
As the chain of modules leading to Order' gets longer it is obviously getting very inconvenient.
(3) It's not rare to have situation where some definitions are interleaved with parameters over which we want to abstract. So we have:
Parameters_1
Definitions_1
Parameters_2
Definitions_2
of course everything can depend on what was above. As putting definitions in module type is not very convenient because then when giving implementation one has to repeat them, for me an obvious solution was to split it into modules and module types as below:
> Module Type MA.
> (* Parameters_1 *)
> End MA.
> Module MB (A: MA).
> (* Definitions_1 *)
> End MB.
> Module Type MC.
> Declare Module A : MA.
> Declare Module B := MB A.
> (* Parameters_2 *)
> End MC.
but the declaration of module B inside MC is rejected by Coq with a message: "Only simple modules allowed in module declarations".
Any suggestions?
Kind regards,
Adam Koprowski
akoprow AT cs.vu.nl,
ICQ: 3204612 -
- The difference between impossible and possible -
- lies in determination (Tommy Lasorda) -
- [Coq-Club] Some problems with modules., Adam Koprowski
- Re: [Coq-Club] Some problems with modules., Frederic Blanqui
