- To: Adam Koprowski <koper AT astercity.net>
- Cc: coq-club AT pauillac.inria.fr, VAN RAAMSDONK Femke <femke AT cs.vu.nl>
- Subject: Re: [Coq-Club] Some problems with modules.
- Date: Wed, 19 May 2004 18:21:29 +0200 (CEST)
On Wed, 19 May 2004, Adam Koprowski wrote:
> (2) Let's say we have a hierarchy of modules one being refinement of
> another.
> For instance modules describing order with more and more assumptions about
> it.
> Below I'll restrict to two modules but in principle there can be much more.
> I can see two methods (at least) of such definition.
> > Module Type Relation.
> > Parameter A: Set.
> > Parameter R: A -> A -> Prop.
> > End Relation.
> > Module Type Order.
> > Parameter A: Set.
> > Declare Module R: Relation with Definition A := A.
> > Parameter R_irr: forall (a: A), ~R.R a a.
> > End Order.
> or
> > Module Type Relation'.
> > Parameter A: Set.
> > End Relation'.
> > Module Type Order'.
> > Declare Module R: Relation.
> > Parameter R_irr: forall (a: R.A), ~R.R a a.
> > End Order'.
> Both approaches have disadvantages. It is possible to avoid them?
> For the first one let's imagine a functor that takes as argument a module
> representing relation and another one representing it's extension to an
> order.
> One would like to write:
> > Module Test (R: Relation)(O: Order with Module R := R).
> which of course is not accepted by Coq (Signature components for label A
> do
> not match)
write O: Order with Definition A := R.A with Module R := R instead!
- [Coq-Club] Some problems with modules., Adam Koprowski
- Re: [Coq-Club] Some problems with modules., Frederic Blanqui
