- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] exctraction : error when compiling extracted OCaml files
- Date: Fri, 04 Jun 2004 14:24:58 +0000
Hello Coq ml,
I have a problem with the Coq extraction of a module and its signature.
I try to extract this code in OCaml :
<-- code extraxt_error.v -->
Module Type SIG.
Parameters (T1 T2 : Set).
Record R : Set := mkr {
r1 : T1 ;
r2 : T2 }.
End SIG.
Module Impl <: SIG.
Definition T1 := nat.
Definition T2 := nat.
r1 : T1 ;
r2 : T1 }.
End Impl.
Extraction "extract_error.ml" Impl.
<-- end code -->
The extraction seems to work fine, and I obtain two files :
"extract_error.ml" and "extract_error.mli".
But when I try to compile extract_error.ml, ocamlc returns this error :
<-- ocamlc error msg -->
The implementation extract_error.ml
does not match the interface extract_error.cmi:
Modules do not match:
sig
type coq_T1 = nat
and coq_T2 = nat
and coq_R = Impl.coq_R = { r1 : coq_T1; r2 : coq_T1; }
val coq_R_rect : (coq_T1 -> coq_T1 -> 'a) -> coq_R -> 'a
val coq_R_rec : (coq_T1 -> coq_T1 -> 'a) -> coq_R -> 'a
val r1 : coq_R -> coq_T1
val r2 : coq_R -> coq_T1
end
is not included in
sig
type coq_T1 = nat
and coq_T2 = nat
and coq_R = Coq_mkr of coq_T1 * coq_T1
end
Type declarations do not match:
type coq_R = Impl.coq_R = { r1 : coq_T1; r2 : coq_T1; }
is not included in
type coq_R = Coq_mkr of coq_T1 * coq_T1
<--- end ocamlc error msg-->
The problem seem to be linked with the extraction of R in the signature
: R becomes a pair while it's supposed to be a record.
What I am supposed to do to have my extracted code to compile ?
These are the files produced by extraction :
<-- extract_error.mli -->
type nat =
| O
| S of nat
module Impl :
sig
type coq_T1 = nat
type coq_T2 = nat
type coq_R =
val coq_R_rect : (coq_T1 -> coq_T1 -> 'a1) -> coq_R -> 'a1
val coq_R_rec : (coq_T1 -> coq_T1 -> 'a1) -> coq_R -> 'a1
end
<-- end extract_error.mli -->
<-- extract_error.ml -->
type nat =
| O
| S of nat
module Impl =
struct
type coq_T1 = nat
type coq_T2 = nat
type coq_R = { r1 : coq_T1; r2 : coq_T1 }
(** val coq_R_rect : (coq_T1 -> coq_T1 -> 'a1) -> coq_R -> 'a1 **)
let coq_R_rect f = function
| { r1 = x; r2 = x0 } -> f x x0
(** val coq_R_rec : (coq_T1 -> coq_T1 -> 'a1) -> coq_R -> 'a1 **)
let coq_R_rec f = function
(** val r1 : coq_R -> coq_T1 **)
let r1 x = x.r1
(** val r2 : coq_R -> coq_T1 **)
let r2 x = x.r2
end
<-- end extract_error.ml -->
- [Coq-Club] exctraction : error when compiling extracted OCaml files, François Armand
