- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] Functor signature ?
- Date: Fri, 04 Jun 2004 15:07:42 +0000
Hello,
I wonder how to use Functor signature in Coq ?
This is my problem :
I want to define a module in which some type are parameterized by type defined in another module. I need to write signature for each module because these sgnatures are used in an other signature.
From now, I've solved the problem like this :
<-- signature and functor definition -->
Module Type MODULE_PARAMS.
Parameter param1 param2 : Set.
End MODULE_PARAMS.
Module Type SIG_MODULE.
Declare Module P : MODULE_PARAMS.
Record E : Set := {
e1 : P.param1 ;
e2 : P.param2
End SIG_MODULE.
(* a functor to automatize creation of a module whose signature is SIG_MODULE *)
Module MakeSigMod (X:MODULE_PARAMS) <: SIG_MODULE with Module P := X.
Module P := X.
Record E : Set := {
e1 : P.param1 ;
e2 : P.param2
End MakeSigMod.
<--- end signature and functor definition --->
And an implementation of SIG_MODULE is done like that, for example :
<--- implementation --->
Require Import List.
Module Impl_params <: MODULE_PARAMS.
Definition param1 := nat.
Definition param2 := list nat.
End Impl_params.
Module Impl_sigmod := MakeSigMod Impl_params.
<--- end implementation --->
This works quite fine, but I think that SIG_MODULE should be a functor's signature, to be cleaner.
So, I attempted to write this, and it does not work :
<--- sigfunct --->
Module Type SIG_FONCTEUR (X:MODULE_PARAMS).
Record E : Set := {
e1 : X.param1 ;
e2 : X.param2
End SIG_FONCTEUR.
(* Implementation... *)
Module MakeSigFonct (X:MODULE_PARAMS) <: SIG_FONCTEUR.
Record E : Set := {
e1 : X.param1 ;
e2 : X.param2
(* End in the following line, I got a Coq error : "User error: Incompatible module types" *)
End MakeSigFonct.
<--- end sigfunct --->
What is the rigth way to define functor signature ?
- [Coq-Club] Functor signature ?, François Armand
- Re: [Coq-Club] Functor signature ?, Jacek Chrzaszcz
