- To: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Computing restricted inductive sets
- Date: Mon, 28 Jun 2004 14:45:36 -0400
Here is a basic example of my question:
Inductive G : Set :=
| a : G1 -> G -> G
| b : G1 -> G
with G1 : Set :=
| c : G1 -> G1 -> G1
| d : nat -> nat -> G1.
Inductive Gp : Set :=
| m : Gp -> Gp -> Gp -> Gp
| n : Gp -> Gp -> Gp
| p : nat -> Gp
| q : nat -> Gp.
Fixpoint D (t : G) : Gp:=
match t with
| a t1 t2 => match t1 with
| c u1 u2 => n (q 1) (D t2)
| d n1 n2 => p n2
end
| b t1 => p 2
end.
(* At this stage, I can involve G terms in proofs, and make Coq compute their translation by D: *)
Goal (D(a (d 1 2) (b (d 2 3))))=(D (b (d 1 2))).
Proof.
simpl; reflexivity.
Qed.
Now, what about computing automatically the subset of Gp given by D? Or in other terms, can Coq compute the inductive set that contains all and only all translations that D can output?
(for example, the construct "m" of Gp is not used in D so "m" will never appear in a term outputted by D;
"q" only occurs as the first subterm of the construct "n", ...)
Thanks,
Pierre
Pierre Geneves/Watson/IBM@IBMUS
Sent by: coq-club-admin AT pauillac.inria.fr 06/23/2004 04:55 PM |
Hello,
I have two different abstract syntaxes G and G', along with a derivor D that maps each construct of G to a specific construct of G' using rewriting rules. I am interested in identifying the abstract syntax of D(G), which is a restriction of G'. Let's consider that both G and G' are first order for now.
I guess that Coq can automatically infer the output inductive type of D(G). I am looking for a convenient way to trigger this computation and print the output.
I have naively started by encoding G as an inductive set definition. I have then tried to encode D as a fixpoint that takes a term of G as a parameter and outputs its translation by D. I have also tried to encode D as rewriting rules for using the "AutoRewrite" tactic. My attempts so far force me to encode G' (ok, but kind of overkill). They allow me to handle instances of G, but I haven't found a way to automatically get D(G) yet. I realize that the answer could be obvious (a simple lemma or definition?) but I don't find it. Also, there might be better ways for encoding my problem...
Any hints, suggestions, or pointers?
Thank you!
Pierre
- [Coq-Club] Computing restricted inductive sets, Pierre Geneves
- Re: [Coq-Club] Computing restricted inductive sets, Pierre Geneves
