- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] Computing restricted inductive sets
- Date: Wed, 23 Jun 2004 16:55:04 -0400
Hello,
I have two different abstract syntaxes G and G', along with a derivor D that maps each construct of G to a specific construct of G' using rewriting rules. I am interested in identifying the abstract syntax of D(G), which is a restriction of G'. Let's consider that both G and G' are first order for now.
I guess that Coq can automatically infer the output inductive type of D(G). I am looking for a convenient way to trigger this computation and print the output.
I have naively started by encoding G as an inductive set definition. I have then tried to encode D as a fixpoint that takes a term of G as a parameter and outputs its translation by D. I have also tried to encode D as rewriting rules for using the "AutoRewrite" tactic. My attempts so far force me to encode G' (ok, but kind of overkill). They allow me to handle instances of G, but I haven't found a way to automatically get D(G) yet. I realize that the answer could be obvious (a simple lemma or definition?) but I don't find it. Also, there might be better ways for encoding my problem...
Any hints, suggestions, or pointers?
Thank you!
Pierre
- [Coq-Club] Computing restricted inductive sets, Pierre Geneves
- Re: [Coq-Club] Computing restricted inductive sets, Pierre Geneves
