- From: Wojciech Moczydlowski <wm174746 AT zodiac.mimuw.edu.pl>
- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] Impredicativity once again
- Date: Sat, 3 Jul 2004 11:35:17 +0200 (CEST)
Hello,
I guess my previous question regarding impredicativity of Prop in Coq was
too vague to be answered. I'll try to reformulate it:
Does anyone know about any developments in Coq's standard library which
would stop "working" if impredicativity from Prop was removed in the same
way the impredicativity of Set was removed in transition to version 8.0?
That is, if the first Prod rule in the reference manual, instead of being
generated by tuples (Type, Prop, Prop), (Set, Prop, Prop), (Prop, Prop,
Prop),
would be generated only by (Set, Prop, Prop) and (Prop, Prop, Prop).
If not, does someone have a suggestion how to find out? Looking through
the standard library by hand doesn't seem to be the right approach (though
maybe I'm missing something very obvious and the answer is trivial).
I was thinking about taking Coq's sources, removing the respective
typing rule and trying to somehow "recompile" the standard library,
but I'm not sure if this has a chance of succeeding.
Thanks,
Wojtek
- [Coq-Club] Impredicativity once again, Wojciech Moczydlowski
- Re: [Coq-Club] Impredicativity once again, Jevgenijs Sallinens
