- To: "Wojciech Moczydlowski" <wm174746 AT zodiac.mimuw.edu.pl>, <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] Impredicativity once again
- Date: Sun, 4 Jul 2004 11:28:19 +0300
Wojciech Moczydlowsi wrote:
>Does anyone
know about any developments in Coq's standard library which
>would stop "working" if impredicativity from Prop was removed in the same >way the impredicativity of Set was removed in transition to version 8.0? >That is, if the first Prod rule in the reference manual, instead of being >generated by tuples (Type, Prop, Prop), (Set, Prop, Prop), (Prop, Prop, Prop), >would be generated only by (Set, Prop, Prop) and (Prop, Prop, Prop). Here attached
archievs with part of my development that show possibility to
build all or most of theory for
natural numbers
without impredicativity. Actually Prop is replaced by Set to demonstrate
this fact.
It seems also
that only Type_0 is required in all places where Type is
used.
See compile.txt to get the order of files and
NatProps.v with final modules that provides operations with
natural numbers and their properties (including
quite general versions for recursion and induction) .
Similar
development is possible also for lists and probably for most of
developments within intuitionistic logic.
It would be very interesting to get expert's opinion.
Kind regards,
Jevgenijs.
Nat.zip
Description: application/compressed
Nat.rar
Description: application/rar-compressed
http://drweb.ru/unix/
- [Coq-Club] Impredicativity once again, Wojciech Moczydlowski
- Re: [Coq-Club] Impredicativity once again, Jevgenijs Sallinens
