coq-club - Re: [Coq-Club] ordinal numbers in Coq
chronological Thread
  • From: Benjamin Werner <werner AT lix.polytechnique.fr>
  • To: Lionel Elie Mamane <lionel AT mamane.lu>
  • Cc: casteran AT labri.fr, coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] ordinal numbers in Coq
  • Date: Wed, 15 Sep 2004 14:23:29 +0200 (CEST)
  Hello,
Again, sorry for the late reply.
Inductive Ord : Type :=
 Ord_cons : (I:Type) (I -> Ord) -> Ord.
I realised that this is exactly the "Ens" type of sets in Benjamin
Werner's encoding of ZF set theory in Coq (contrib Rocq/ZF). I created
my Conway Games type by taking inspiration from Ens, so "la boucle est
bouclée".
In general it depends of what ordinals you want to deal with. You can get a subset of the set-theoretical ordinals with the well-known example (but Pierre is certainly aware of that) :
   O_Ord : Ord
 | S_ord : Ord -> Ord
 | lim_Ord : (nat->Ord) -> Ord.
Which is a form of ordinal notation.
When considering ordinals like in set-theory, the problem is that the usual definition is fundamentally classical (ordinals are sets which, among other things, have the property that their elements are totaly ordered wrt. membership).
Paul Taylor has a big paper where he develops ordinals constructively. On the other hand, he heavily relies on impredicativity. A few years back, I adapted his developement into Coq (on top of the Ens type) and it works quite well. I did not know what to do with this and have not advertized this work. If you think you have a use for it, I would be happy to talk about it.
Amities,
Benjamin
