- To: casteran AT labri.fr
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] (no subject)
- Date: Sat, 18 Sep 2004 03:19:19 +1000
- Comments: In-reply-to casteran AT labri.fr message dated "Fri, 17 Sep 2004 18:17:57 +0200."
Hi Pierre,
I guess you can avoid using an axiom.
I think the proof below does not use any axiom.
It uses a lot of definitions from the Eqdep_dec.v file
in the Coq library.
I think the reason why you can prove
forall v:(vect bool 0), v=vnil
is that equality on nat is decidable. It allows you to use
use the K_dec lemma and complete the proof.
By the way, I think it would be useful to have a command like
Print Axioms. in order to be able to see what axioms are
loaded with librairies and maybe also a dependency analysis
to make sure a given theorem does not rely on any axiom...
Nicolas
Require Export Arith.
Set Implicit Arguments.
Section DecidableEqDep.
Variable A : Type.
Let comp (x y y':A) (eq1:x = y) (eq2:x = y') : y = y' :=
eq_ind _ (fun a => a = y') eq2 _ eq1.
Remark trans_sym_eq : forall (x y:A) (u:x = y), comp u u = refl_equal y.
intros.
case u; trivial.
Qed.
Variable eq_dec : forall x y:A, x = y \/ x <> y.
Variable x : A.
Let nu (y:A) (u:x = y) : x = y :=
match eq_dec x y with
| or_introl eqxy => eqxy
| or_intror neqxy => False_ind _ (neqxy u)
end.
Let nu_constant : forall (y:A) (u v:x = y), nu u = nu v.
intros.
unfold nu in |- *.
case (eq_dec x y); intros.
reflexivity.
case n; trivial.
Qed.
Let nu_inv (y:A) (v:x = y) : x = y := comp (nu (refl_equal x)) v.
Remark nu_left_inv : forall (y:A) (u:x = y), nu_inv (nu u) = u.
intros.
case u; unfold nu_inv in |- *.
apply trans_sym_eq.
Qed.
Theorem eq_proofs_unicity : forall (y:A) (p1 p2:x = y), p1 = p2.
intros.
elim nu_left_inv with (u := p1).
elim nu_left_inv with (u := p2).
elim nu_constant with y p1 p2.
reflexivity.
Qed.
Theorem K_dec :
forall P:x = x -> Prop, P (refl_equal x) -> forall p:x = x, P p.
intros.
elim eq_proofs_unicity with x (refl_equal x) p.
trivial.
Qed.
End DecidableEqDep.
(** We deduce the [K] axiom for (decidable) Set *)
Theorem K_dec_set :
forall A:Set,
(forall x y:A, {x = y} + {x <> y}) ->
forall (x:A) (P:x = x -> Prop), P (refl_equal x) -> forall p:x = x, P p.
intros.
elim p using K_dec.
intros.
case (H x0 y); intros.
elim e; left; reflexivity.
right; red in |- *; intro neq; apply n; elim neq; reflexivity.
trivial.
Qed.
Section def.
Variable A:Set.
Inductive vect: nat -> Set :=
vnil: vect O
| vcons:forall n:nat, A -> (vect n) -> (vect (S n)).
Lemma uniq : forall v:(vect 0), v=vnil.
intros v.
change (v= (eq_rec O vect vnil O (refl_equal O))).
generalize (refl_equal O).
change
((fun (n : nat) (v : vect n) =>
forall e : 0 = n, v = eq_rec _ vect vnil _ e) 0 v)
in |- * .
case v; intros.
apply K_dec_set with (p := e).
exact eq_nat_dec.
reflexivity.
discriminate e.
Qed.
End def.
- [Coq-Club] (no subject), casteran
- Re: [Coq-Club] (no subject), Nicolas Magaud
- Re: [Coq-Club] (no subject), Thery Laurent
