- To: casteran AT labri.fr
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] (no subject)
- Date: Fri, 17 Sep 2004 19:43:02 +0200 (CEST)
Hi,
Below is a simple proof that the only vector of length 0 is
Vnil. But this proof uses the axiom JMeq_eq. Is there any axiom-free
proof of the same result ?
It is always the same trick as explained by Pierre Letouze:
http://coq.inria.fr/mailing-lists/coqclub/200404/msg00002.html
It is also used in the definition of monomials in my buchberger development:
ftp://ftp-sop.inria.fr/lemme/Laurent.Thery/Buchberger/index.html
You first define a variant of the identity function to get rid of the dependency:
Definition vector_id : forall n : nat, vector bool n -> vector bool n.
intros n; case n.
intros H'; exact (Vnil bool).
intros n1 H'; exact H'.
Defined.
Prove that it is indeed the identity
Theorem vector_id_is_id : forall n (v: vector bool n), v = vector_id n v.
intros n v; case v; simpl in |- *; auto.
Qed.
And the trick is done
Theorem vector_eq_0 : forall v : vector bool 0, v = Vnil bool.
intros v; exact (vector_id_is_id 0 v).
Qed.
Laurent
- [Coq-Club] (no subject), casteran
- Re: [Coq-Club] (no subject), Nicolas Magaud
- Re: [Coq-Club] (no subject), Thery Laurent
