- From: S�bastien Hinderer <Sebastien.Hinderer AT loria.fr>
- To: Dan Synek <synek AT cs.ru.nl>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] trivial ltac question
- Date: Tue, 21 Sep 2004 12:02:02 +0200
Hi Dan,
> How do I rewrite this code so that the error message gets returned?
> Lemma F:False.
> match goal with
> | _ => fail "error message"
> end.
> (It prints the following error message:
> User error: No matching clauses for match goal
> thanks
To print an error message, you can use
idtac "Error!"
It is not very elegant but it's the only solution I know.
If I recall correctly, the problem with fail is that it makes the matching
fail, too. Then, due to Coq's backtracking features, the system looks for a
new pattern to match the goal. Since none is found, the message you gave is
displayed.
Using idtac should solve all this.
Hope this helps,
Sébastien.
- [Coq-Club] trivial ltac question, Dan Synek
- Re: [Coq-Club] trivial ltac question, Sébastien Hinderer
- Re: [Coq-Club] trivial ltac question, Dan Synek
- Re: [Coq-Club] trivial ltac question, Hugo Herbelin
