coq-club - Re: [Coq-Club] trivial ltac question
chronological Thread
  • To: S�bastien Hinderer <Sebastien.Hinderer AT loria.fr>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] trivial ltac question
  • Date: Tue, 21 Sep 2004 14:04:12 +0200
So, there is no way to make an Ltac return an error message from within a
match. Is it not time to fix this? Maybe an explicit break statement or something.
The idtac solution I do not like, since I want an error mesage and not just a printed message followed by an ununderstandable error message (from the users point of view).
Thanks anyway  Se'bastien
Dan
Sébastien Hinderer wrote:
Hi Dan,
How do I rewrite this code so that the error message gets returned?
Lemma F:False.
match goal with
 | _ => fail "error message"
end.
(It prints the following error message:
User error: No matching clauses for match goal
thanks
To print an error message, you can use
idtac "Error!"
It is not very elegant but it's the only solution I know.
If I recall correctly, the problem with fail is that it makes the matching
fail, too. Then, due to Coq's backtracking features, the system looks for a
new pattern to match the goal. Since none is found, the message you gave is
displayed.
Using idtac should solve all this.
Hope this helps,
Sébastien.
Bug reports: http://coq.inria.fr/bin/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
         http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
