- To: anoun AT labri.fr
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] tactics with parameters
- Date: Tue, 28 Sep 2004 10:38:39 +0200
Hello Houda,
This is because H is considered as a pattern variable and is
no more bound to the name 'H'.
You can use "type of" :
Ltac elimAnd H:=
let typ := type of H in
match typ with ?A /\ ?B => elim H
end.
Lemma tryTac:forall (A B:Prop), A/\B ->A/\A->B.
intros A B H H0.
elimAnd H.
auto.
Qed.
Pierre
Selon Houda Anoun
<anoun AT labri.fr>:
> Hi everybody,
> I want to define a tactic that has an argument H which is a name of an
> hypothesis of the context that will be used if some conditions are
> verified to simplify the current goal
> An example of such tactics is the following one: elimAnd
> Ltac elimAnd H:=
> match goal with H:?A/\?B |- _=>elim H; clear H; intros
> | _ =>idtac
> end.
> The tactic that I want to define has one argument H , the tactic has to
> check that the type of H is of the form A/\B if this is the case the
> tactic elim this hypothesis otherwise it does nothing
> Unfortunately while trying to test elimAnd I found that it doesn't
> always elim the hypothesis whose name is given as a parameter specially
> when the context contains several hypothesis of the form _/\_!
> An example of that is the following:
> intros A B H H0.
> elimAnd H.
> -------here the tactic elim H0 instead of H!!
> How can we solve the probleme without defining the tactic in ocaml?
> Concerning the definition of tactics using ocaml is there any tutorial
> explaining that and giving some basic examples??
> Thanks a lot in advance
> Houda
> | Houda ANOUN |
> | LaBRI |
> | 351 Cours de la libération |
> | 33405 Talence |
> | phone: 0540002489 |
>Â :anoun AT labri.fr
> Bug reports: http://coq.inria.fr/bin/coq-bugs
> Archives: http://pauillac.inria.fr/pipermail/coq-club
> http://pauillac.inria.fr/bin/wilma/coq-club
> Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
This message was sent using IMP, the Internet Messaging Program.
- [Coq-Club] tactics with parameters, Houda Anoun
- Re: [Coq-Club] tactics with parameters, casteran
