- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] tactics with parameters
- Date: Tue, 28 Sep 2004 10:22:35 +0200
Hi everybody,
I want to define a tactic that has an argument H which is a name of an hypothesis of the context that will be used if some conditions are verified to simplify the current goal
An example of such tactics is the following one: elimAnd
Ltac elimAnd H:=
match goal with H:?A/\?B |- _=>elim H; clear H; intros
| _ =>idtac
end.
The tactic that I want to define has one argument H , the tactic has to check that the type of H is of the form A/\B if this is the case the tactic elim this hypothesis otherwise it does nothing
Unfortunately while trying to test elimAnd I found that it doesn't always elim the hypothesis whose name is given as a parameter specially when the context contains several hypothesis of the form _/\_!
An example of that is the following:
Lemma tryTac:forall (A B:Prop), A/\B ->A/\A->B.
intros A B H H0.
elimAnd H.
-------here the tactic elim H0 instead of H!!
How can we solve the probleme without defining the tactic in ocaml?
Concerning the definition of tactics using ocaml is there any tutorial explaining that and giving some basic examples??
Thanks a lot in advance
Houda
| Houda ANOUN |
| LaBRI |
| 351 Cours de la libération |
| 33405 Talence |
| phone: 0540002489 |
:anoun AT labri.fr
- [Coq-Club] tactics with parameters, Houda Anoun
- Re: [Coq-Club] tactics with parameters, casteran
