coq-club - Re: [Coq-Club] "Signature checking" of .vo files?
chronological Thread
  • To: Adam Chlipala <adamc AT cs.berkeley.edu>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] "Signature checking" of .vo files?
  • Date: Wed, 06 Oct 2004 19:47:23 +0200
Adam Chlipala wrote :
I would like to check that a .vo file satisfies a certain "signature," in an ML-like sense. I want to create a file with a list of identifiers and their types, possibly with earlier identifiers bound in the types of later identifiers. Then, I want an automated tool to check that a certain .vo file defines each identifier with a type equivalent to the one I have specified. It would also be fine to be able to perform a series of actions in coqtop and then ask it to check that identifiers have been defined according to a given signature. Is there a canonical way to do this with Coq?
Assume you want to check that A.vo has a signature compatible with a module type B.
You just have to do on the toplevel (or in a file):
Require A.
Module test <: B := A.
for instance:
Module Type S.
 Inductive nat:Set := O | S(n:nat).
End S.
Module test_ok <: S := Datatypes.
Require List.
Module test_not_ok <: S := List.
Hope this answers your question.
Bruno Barras.
