coq-club - Re: [Coq-Club] "Signature checking" of .vo files?
chronological Thread
  • From: Robert R Schneck-McConnell <schneck AT math.berkeley.edu>
  • To: coq-club AT pauillac.inria.fr
  • Cc: Adam Chlipala <adamc AT cs.berkeley.edu>
  • Subject: Re: [Coq-Club] "Signature checking" of .vo files?
  • Date: Wed, 6 Oct 2004 19:01:35 -0400
On Wed, 6 Oct 2004, Bruno Barras wrote:
> Adam Chlipala wrote :
> > I would like to check that a .vo file satisfies a certain "signature,"
> > in an ML-like sense.
> Assume you want to check that A.vo has a signature compatible with a
> module type B.
> You just have to do on the toplevel (or in a file):
> Require A.
> Module test <: B := A.
This works, to an extent, but it allows that A only *declares* the
required entities, as Parameters or Axioms.
Is there a canonical way to check or require that a module *defines*
all of its elements?
Robert
