- From: "Claudia Fernanda Oliveira K Tavares" <claudia AT consiste.dimap.ufrn.br>
- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] Still adding modules...
- Date: Thu, 28 Oct 2004 15:30:30 +0000
Hello!
I've written to Coq Club and some people answered, but I continue with my
problem. So I'm going to explain better.
I downloaded one folder called "blinc" that contains many files of module
type ("filename.v"), I saved in "C:\Coq\lib\theories\blinc" path and I'm
trying to use in Coq (for Linux and for Windows).
The resumed hierarchy of files is in this way:
blinc: claus.v - mcf_thm.v - nnf_thm.v - and other modules (no compiled)
|_theta: theta.v (no compiled)
|_newman : newman_assym.v (no compiled)
I had some problems because it has a dependency between the files and I
don't get to compile the files:
- I can't test the sample applications because I add the directory "blinc"
in loadpath:
Coq < Add LoadPath "blinc".
Coq < Add LoadPath "blinc/theta".
Coq < Add LoadPath "blinc/newman".
- But when a try to load the "theta.v" module, it causes an error:
Coq < Load theta.
Error while reading /home/consiste/claudia/Programas/coq-
8.0/theories/blinc/theta/theta.v :
File "/home/consiste/claudia/Programas/coq-
8.0/theories/blinc/theta/theta.v", line 1, characters 8-13
User error: Cannot find library claus in loadpath
- So, I try to load the "claus.v" module, it causes an error too:
Coq < Load claus.
8.0/theories/blinc/claus.v :
8.0/theories/blinc/claus.v", line 3, characters 15-22
User error: Cannot find library mcf_thm in loadpath
- I try to load "mcf_thm" module that require other module and so on...
What's wrong? Could anyone help me?
Regards,
Cláudia.
Consiste/DIMAp (http://www.consiste.dimap.ufrn.br/)
- [Coq-Club] coq 8.0 errors, Stefan Karrmann
- Re: [Coq-Club] coq 8.0 errors,
Lionel Elie Mamane
- [Coq-Club] Still adding modules..., Claudia Fernanda Oliveira K Tavares
- Re: [Coq-Club] Still adding modules..., Jean-Christophe Filliatre
Lionel Elie Mamane
