- From: Jean-Christophe Filliatre <Jean-Christophe.Filliatre AT lri.fr>
- To: "Claudia Fernanda Oliveira K Tavares" <claudia AT consiste.dimap.ufrn.br>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Still adding modules...
- Date: Thu, 28 Oct 2004 17:52:27 +0200
Claudia Fernanda Oliveira K Tavares writes:
> I had some problems because it has a dependency between the files and I
> don't get to compile the files:
> - But when a try to load the "theta.v" module, it causes an error:
> Coq < Load theta.
> Error while reading /home/consiste/claudia/Programas/coq-
> 8.0/theories/blinc/theta/theta.v :
> File "/home/consiste/claudia/Programas/coq-
> 8.0/theories/blinc/theta/theta.v", line 1, characters 8-13
> User error: Cannot find library claus in loadpath
The message "Cannot find library claus" indicates that Coq is looking
for a compiled version of claus.v, that is claus.vo, when interpreting
a command such as "Require claus". So you probably forgot to compile
claus.v first.
Jean-Christophe
- [Coq-Club] coq 8.0 errors, Stefan Karrmann
- Re: [Coq-Club] coq 8.0 errors,
Lionel Elie Mamane
- [Coq-Club] Still adding modules...,
- Re: [Coq-Club] Still adding modules..., Jean-Christophe Filliatre
Lionel Elie Mamane
