- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] problem with dependant types
- Date: Wed, 10 Nov 2004 14:52:39 +0100
Hello,
I have some difficulties while using dependant types, more precisely when
defining inductive predicate and doing inversion on them. An hypothesis of
the form:
H : existS (fun x : T1 => T2) y v1 = existS (fun x : T1 => T2) y v2
appears and sometimes v2 as been changed into v1 in my goal (after
simplification of projs2(existS ...)), but sometimes no and I cannot deduce
anything like v1=v2 (injection doesn't work...). And in my goal I have a
"match...in...return...with...end" form that I don't really understand (I
don't really understand the "in..." part)...
Since I'm not very familiar with dependant types, I cannot say whether it
comes from my definitions or if it's a theoretical problem ... I would be
grateful if someone can give me some indications.
Hereafter is the whole problem (sorry if it's a bit long, I didn't manage to
explain it in a shorter manner)
Thanks in advance
June Andronick
(* I have the following definition of lists of size n : *)
Inductive listn : nat -> Set :=
| niln : listn 0
| consn : forall n:nat, nat -> listn n -> listn (S n).
(* I defined a predicate for the ith element of the list : *)
Inductive ith :
forall (n:nat), listn (S n) -> nat -> nat -> Prop :=
| IthBitFirst : forall (nn:nat) (elt:nat) (tl:listn nn),
(ith nn (consn nn elt tl) 0 elt)
| IthBitNotFirst :
forall (nn:nat) (elt:nat) (tl:listn (S nn)) (i:nat) (res:nat),
(ith nn tl i res) ->
(ith (S nn) (consn (S nn) elt tl) (S i) res) .
(* The case where it works : *)
Parameter un_op : nat -> nat.
Fixpoint listn_un_op (n:nat)(l:listn n){struct l}: listn n :=
match l in listn n return listn n with
| niln => niln
| consn n' a y => consn n' (un_op a) (listn_un_op n' y)
end.
Lemma ith_of_listn_un_op :
forall i n l res,
(ith n l i res) ->
(ith n (listn_un_op (S n) l) i (un_op res)).
Proof.
induction i; intros; inversion H; simpl; subst; constructor.
apply (IHi nn tl res); auto.
Qed.
(* The case where it doesn't work *)
(* (by the way, I didn't manage to define listn_bin_op with Fixpoint and
"match ... in..." like the listn_un_op definition ..........) *)
Parameter bin_op : nat -> nat -> nat.
Definition listn_bin_op :
forall (n:nat), listn n -> listn n -> listn n.
Proof.
induction n as [|n hyp_rec_n]; intros l1 l2. exact niln.
inversion l1 as [|nn a1 tl1]; inversion l2 as [|nnn a2 tl2]; subst.
exact (consn n (bin_op a1 a2) (hyp_rec_n tl1 tl2)).
Defined.
Lemma ith_of_listn_bin_op :
forall i n l1 l2 res1 res2,
(ith n l1 i res1) -> (ith n l2 i res2) ->
(ith n (listn_bin_op (S n) l1 l2) i (bin_op res1 res2)).
Proof.
induction i; intros.
inversion H; inversion H0; simpl; subst.
- [Coq-Club] problem with dependant types, june andronick
- Re: [Coq-Club] problem with dependant types,
casteran
casteran
Nicolas Magaud
Venanzio Capretta
Conor McBride
Venanzio Capretta
- Re: [Coq-Club] problem with dependant types, Cuihtlauac ALVARADO
- Re: [Coq-Club] problem with dependant types, Conor McBride
- Re: [Coq-Club] problem with dependant types, Venanzio Capretta
Venanzio Capretta
- Re: [Coq-Club] problem with dependant types, James McKinna
Conor McBride
Venanzio Capretta
Nicolas Magaud
casteran
casteran
