- From: Cuihtlauac ALVARADO <cuihtlauac.alvarado AT francetelecom.com>
- To: Venanzio Capretta <Venanzio.Capretta AT mathstat.uottawa.ca>
- Cc: Conor McBride <conor AT cs.rhul.ac.uk>, Nicolas Magaud <nmagaud AT cse.unsw.edu.au>, casteran AT labri.fr, june andronick <jandronick AT axalto.com>, coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] problem with dependant types
- Date: Thu, 18 Nov 2004 17:09:08 +0100
- Organization: France Telecom - R&D - MAPS/AST
> > What's so bad about K anyway?
> >Dependent pattern matching is currently difficult in Coq, but it doesn't
> >have to be that way. The question is what to do about it.
> >On conna\^it la chanson...
> I don't have anything in particular agains K, but in general I don't
> like axioms. When you are forced to use an axiom it means that your type
> theory is not doing the job. One should rather rething the system so
> that the desired properties are "structural" rather that axiomatic.
> In the case under study, Pierre Casteran showed how to do things without
> assuming axioms, if you can do without them you should.
> A part from this philosophical point, I have no objection: go ahead and
> use K!
On the other hand you can prove K for (vect A) if equality over A is
decidable, which happens, sometimes :-)
Cuihtlauac ALVARADO - France Telecom - R&D - +33296053273
2, av Pierre Marzin - 22307 Lannion - France
- [Coq-Club] problem with dependant types, june andronick
- Re: [Coq-Club] problem with dependant types,
casteran
casteran
Nicolas Magaud
Venanzio Capretta
Conor McBride
Venanzio Capretta
- Re: [Coq-Club] problem with dependant types, Cuihtlauac ALVARADO
- Re: [Coq-Club] problem with dependant types, Conor McBride
- Re: [Coq-Club] problem with dependant types, Venanzio Capretta
Venanzio Capretta
- Re: [Coq-Club] problem with dependant types, James McKinna
Conor McBride
Venanzio Capretta
Nicolas Magaud
casteran
casteran
- Re: [Coq-Club] problem with dependant types, Boris Yakobowski
- Re: [Coq-Club] problem with dependant types, casteran
- <Possible follow-ups>
- Re: [Coq-Club] problem with dependant types, june andronick
