coq-club - Re: [Coq-Club] Saving proofs?
chronological Thread
  • To: Wojciech Moczydlowski <wm174746 AT zodiac.mimuw.edu.pl>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Saving proofs?
  • Date: Wed, 22 Dec 2004 11:47:18 +0100
Selon Wojciech Moczydlowski
<wm174746 AT zodiac.mimuw.edu.pl>:
>   Hello,
> I have a question regarding saving proofs in Coq, namely, how to do it.
> That is, I would like to be able to do the following (in coqtop).
> 1. State some lemma.
> 2. Prove it (using coqtop).
> 3. Somehow save the proof (and lemma) so that next time I can proceed with
> the development with the lemma proved.
> What I've been doing so far was stating the lemmas in the .v file, and
> simply pasting proofs to this file; this methodology, though, stopped
> being sufficient once proofs got large. The Write State command, which
> from the description could be what I'm looking for, doesn't seem to be
> working.
You can deal with large proofs in the same as in programming languages:
use several files and compile them separately (Require is fast).
You can build a makefile and use the coqdep command to build dependencies.
The inconvenient of this is that once you have Qed'ed a proof, you need
to compile the file to use the lemma in another file. If you keep files
small the annoyance is acceptable.
Cheers,
Pierre
> Thanks,
> Wojtek
> Bug reports: http://coq.inria.fr/bin/coq-bugs
> Archives: http://pauillac.inria.fr/pipermail/coq-club
>           http://pauillac.inria.fr/bin/wilma/coq-club
> Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
