coq-club - Re: [Coq-Club] Implicit arguments
chronological Thread
  • To: Jevgenijs Sallinens <jevgenijs AT dva.lv>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Implicit arguments
  • Date: Wed, 22 Dec 2004 17:09:26 +0900
  • Organization: JAIST
Dear Jevgenijs,
Your proposal only eliminates the use of P (inside its scope), right? My interest lies outside the section and is not really related to P (as a local/global parameter).
In case it isn't clear, the idea is to use Theorem deskolemise to conclude forall-exists results from previously proved exists-forall results. I would like to do this without wrapping the(!) body of two considered predicates up as a function and pass to deskolemise in addition to the exists-forall proof. Doing so is not troublesome, of course, but it is not elegant, either, and it raises the entry level for parsing the proof.
Cheers,
RV
Jevgenijs Sallinens wrote:
 > Rene Vestergaard wrote:
 > When invoking it, the specific P needs to be listed in addition to the
 > formula being deskolemised. Is there a nice/standard alternative whose
 > uses are implicit about the P?
Dear Rene,
I hope the following could help by hiding P with coercion.
If nothing depends on specific structure of P, probably better to declare it as global parameter. Regards,
Jevgenijs.
Section Deskolemise.
Variable A : Type.
Variable B : Type.
Variable P : A -> B -> Prop.
Coercion P: A >->  Funclass.
Theorem deskolemise : (exists F : A -> B, forall a : A , a (F a))
                       -> forall a : A , exists b : B , a b.
intro skolemised. elim skolemised.
intros F gConcl arg. exists (F arg). apply gConcl.
Qed.
End Deskolemise.
