- From: Yevgeniy Makarov <emakarov AT cs.indiana.edu>
- To: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Manipulating proof terms
- Date: Mon, 21 Feb 2005 01:27:18 -0500
Hi,
have you read documentation chapter 18 ('Extraction of programs in
Objective Caml and Haskell', cf.
<http://pauillac.inria.fr/coq/doc8/Reference-Manual021.html>)?
I cannot use standard Extraction mechanism because, in order to get computational content of classical proofs, I cannot ignore subderivations of atoms. I'd like to use standard predicates =, <, etc. (for example, because then I can use tactics like ring), but then derivations of equalities are not included in the extracted program.
Another reason is that there is neither ~ nor double negation elimination tactic NNPP for Set.
If I am able to analyze a proof term then I can prove everything with respect to Prop and then run functions like or_ind, which are not included in the output program if I use Extraction.
Yevgeniy
- [Coq-Club] Manipulating proof terms, Yevgeniy Makarov
- Re: [Coq-Club] Manipulating proof terms, Stefano Zacchiroli
Stefan Karrmann
- Re: [Coq-Club] Manipulating proof terms, Yevgeniy Makarov
- Re: [Coq-Club] Manipulating proof terms, Claudio Sacerdoti Coen
Hugo Herbelin
- Re: [Coq-Club] Manipulating proof terms, Pierre Letouzey
