- From: Stefan Karrmann <sk AT mathematik.uni-ulm.de>
- To: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Check time and space consumption
- Date: Wed, 23 Feb 2005 22:49:06 +0100
- Mail-reply-to: <sk AT mathematik.uni-ulm.de>
Hello!
AFAIKS it is not difficult to calculate an upper bound O(f) for the time
complexity from Coq's function definitions. It is a kind of counting
reduction steps. It is roughly done by T as follows:
T(match e0 with | p1 => e1 | ... | p_n => e_n end)
:= T(e0) + max { T(e_i) + i | 1 <= i <= n }.
(* I assume that the (simple) pattern match takes one unit of time or
reduction step, respectivly. *)
T(fix f (args) { struct s } := e)
:= T(e with recursive calls of f replaced by a constant) * depth(s).
(* where depth(s) counts the `inductive depth of s', e.g.
forall n:nat, depth(n) := n.
forall t:binary_tree A, depth(t) := binary_tree_depth(t)
Note, that s becomes an argument to the complexity function.
Lower bounds and space complexity can calculated in a similar way. How can
we handle cofix definitions?
The calculation of space complexity should have an extra branch for tail
recursive functions.
Benjamin Werner (Sun, Feb 20, 2005 at 10:42:42PM +0100):
> Hallo,
> Coq does not provide tools for checking complexity of programs. It
> should be interesting to see what external complexity checking tools
> could do with code coming from coq (I thought about doing this with
> Paul Zimmermann's LUO - lambda epsilon omega but never completed this).
Where can I find Paul Zimmermann's LUO? Well, I will try Google.
> If you want to state internally results about the complexity, this is a
> little difficult (see the discussion about extentional equality) but
> not unfeasible (see Constable et. al.' s approach for instance).
> I general, it should be noted that allthough all coq programs
> terminate, they can take a very very long time; in other words, they
> cover all practical complexity classes.
> Cheers,
> Benjamin
> Le 20 févr. 05, à 00:34, Stefan Karrmann a écrit :
> >functions which are defined and accepted in Coq terminates. Can the system
> >check space and time upper bounds, i.e. O(f) bounds?
> >Take for example the addition of the Coq 8 library:
> >(** Addition *)
> >Fixpoint plus (n m:nat) {struct n} : nat :=
> > match n with
> > | O => m
> > | S p => S (plus p m)
> > end.
> >We have:
> > (plus n m) in time O(n)
> >and:
> > (plus n m) in space O(n + m)
> > (* the result has this length *)
> >How can this be checked in or by Coq?
Regards,
Stefan Karrmann
- [Coq-Club] Check time and space consumption, Stefan Karrmann
- Re: [Coq-Club] Check time and space consumption,
Benjamin Werner
- Re: [Coq-Club] Check time and space consumption, Stefan Karrmann
- Re: [Coq-Club] Check time and space consumption, Benjamin Werner
Benjamin Werner
