coq-club - Re: [Coq-Club] Check time and space consumption
chronological Thread
  • From: Benjamin Werner <benjamin.werner AT polytechnique.fr>
  • To: sk AT mathematik.uni-ulm.de
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Check time and space consumption
  • Date: Thu, 24 Feb 2005 00:02:33 +0100
Hi,
Hello!
AFAIKS it is not difficult to calculate an upper bound O(f) for the time
complexity from Coq's function definitions. It is a kind of counting
reduction steps. It is roughly done by T as follows:
T(fix f (args) { struct s } := e)
 := T(e with recursive calls of f replaced by a constant) * depth(s).
 (* where depth(s) counts the `inductive depth of s', e.g.
    forall n:nat, depth(n) := n.
    forall t:binary_tree A, depth(t) := binary_tree_depth(t)
    Note, that s becomes an argument to the complexity function.
Are you sure you do not make some implicit linearity assumptions ?
Would your idea apply to Ackermann's function ?
Also (but this is a minor point) it would not work for inductive types which are not datatypes because you cannot define a finite depth then. Take :
Inductive ord : Set :=
OO : ord
| SO : ord -> ord
| lim : (nat->ord) -> ord.
Where can I find Paul Zimmermann's LUO? Well, I will try Google.
I would not know a better pointer :-). He is at LORIA (INRIA-Nancy) now. But since his PhD was in Rocquencourt, you can look at
http://algo.inria.fr/libraries/software.html#luo
(I did not check further recently).
Cheers,
Benjamin
