- To: Coq Club <coq-club AT pauillac.inria.fr>
- Subject: [Coq-Club] Impredicate Set requirement.
- Date: Wed, 2 Mar 2005 11:18:26 -0500 (EST)
I don't understand why
Inductive Lambda : Set -> Set :=
| var : forall A:Set, A -> Lambda A
| app : forall A:Set, Lambda A -> Lambda A -> Lambda A.
is considered impredicative, but
Inductive Lambda (A:Set) : Set :=
| var : A -> Lambda A
| app : Lambda A -> Lambda A -> Lambda A.
is considered predicative. The two types seem isomorphic to me.
I really want to define
| lambda : forall A:Set, Lambda (option A) -> Lambda A.
which is almost uniformly parametric polymorpic. This definition strikes
me as just as safe as polymorphic lists.
I cannot fix this my changing Set to Type because then the statement of
the join function:
Definition joinStatement :=
forall (T:Type)(l:Lambda (Lambda T)),(Lambda T).
causes a universe inconsistency.
Russell O'Connor <http://r6.ca/>
``All talk about `theft,''' the general counsel of the American Graphophone
Company wrote, ``is the merest claptrap, for there exists no property in
ideas musical, literary or artistic, except as defined by statute.''
- [Coq-Club] non-uniform parametric types challenge, roconnor
- Re: [Coq-Club] non-uniform parametric types challenge, roconnor
- [Coq-Club] Re: non-uniform parametric types challenge,
roconnor
- Re: [Coq-Club] Re: non-uniform parametric types challenge, roconnor
- [Coq-Club] Impredicate Set requirement., roconnor
- [Coq-Club] Non-uniform parametric inductive types,
roconnor
- Re: [Coq-Club] Non-uniform parametric inductive types, Christine Paulin
Hugo Herbelin
- Re: [Coq-Club] Non-uniform parametric inductive types, Bas Spitters
- Re: [Coq-Club] Impredicate Set requirement., Claudio Sacerdoti Coen
roconnor
