- From: Christine Paulin <Christine.Paulin AT lri.fr>
- To: roconnor AT theorem.ca
- Cc: Coq Club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] Non-uniform parametric inductive types
- Date: Wed, 9 Mar 2005 17:57:45 +0100
You need to define:
Inductive term Set -> Set :=
| Var : forall A:Set, A -> term A
| App : forall A:Set, term A -> term A -> term A
| Fun : forall A:Set, term (option A) -> term A.
Christine Paulin
writes:
> Let me modify my previous question as follows. Why must the parameters in
> a parametric inductive definition be uniform? For example, why should the
> following declaration rejected:
> Inductive term (A:Set) : Set :=
> | Var : A -> term A
> | App : term A -> term A -> term A
> | Fun : term (option A) -> term A.
> The data type is still well-founded. I would expect the generated
> elimination rule to have a type such as:
> term_rec : forall
> (P:forall A:Set, term A -> Set)
> (A:Set)
> (var_case:forall a:A, P A (Var A a))
> (app_case:forall a b:term A, P A a -> P A b -> P A (App A a b))
> (fun_case:forall a:term (option A), P (option A) a -> P A (Fun A a))
> (a:term A),
> (P A a).
> Would modifying Coq to allow non-uniform parametric inductive types lead
> to an inconsistency or other badness?
> Russell O'Connor <http://r6.ca/>
> ``All talk about `theft,''' the general counsel of the American Graphophone
> Company wrote, ``is the merest claptrap, for there exists no property in
> ideas musical, literary or artistic, except as defined by statute.''
> Bug reports: http://coq.inria.fr/bin/coq-bugs
> Archives: http://pauillac.inria.fr/pipermail/coq-club
> http://pauillac.inria.fr/bin/wilma/coq-club
> Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
Christine Paulin-Mohring mailto :
LRI, UMR 8623 CNRS, Bat 490, Université Paris Sud, 91405 ORSAY Cedex
tel : (+33) (0)1 69 15 66 35 fax : (+33) (0)1 69 15 65 86
- [Coq-Club] non-uniform parametric types challenge, roconnor
- Re: [Coq-Club] non-uniform parametric types challenge, roconnor
- [Coq-Club] Re: non-uniform parametric types challenge,
roconnor
- Re: [Coq-Club] Re: non-uniform parametric types challenge, roconnor
- [Coq-Club] Impredicate Set requirement.,
roconnor
- [Coq-Club] Non-uniform parametric inductive types,
roconnor
- Re: [Coq-Club] Non-uniform parametric inductive types, Christine Paulin
Hugo Herbelin
- Re: [Coq-Club] Non-uniform parametric inductive types, Bas Spitters
- Re: [Coq-Club] Impredicate Set requirement., Claudio Sacerdoti Coen
roconnor
