- To: Robert Dockins <robdockins AT fastmail.fm>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] mutually inductive definition
- Date: Tue, 8 Mar 2005 08:37:53 +0100
On Mon, Mar 07, 2005 at 09:02:59PM -0500, Robert Dockins wrote:
> I'm trying to define a type which has a uniqueness property. I thought
> I'd define the type to be mutually inductive with a proposition type
> indicating the uniqueness:
> However, coq rejects the definition, complaining,
> Error: The reference uniq_list was not found in the current environment.
What you are trying to do (as you said yourself) is defining a type
and a predicate on this type mutually inductive; this is called
induction-recursion, and is not supported by the CIC (calculus of
inductive constructions), the type theory behind Coq. AFAIK, the
canonical reference for the notion is:
Peter Dybjer, A general formulation of simultaneous
inductive-recursive definitions in type theory, Journal of Symbolic
Logic, 65(2), June 2000.
Notice the relatively recent date :-) But maybe someone will correct
me and say that the notion was known for longer.
In Coq, you define list, then define notin, then define (e.g.) a
record type holding a list and the uniqueness property; the concept of
"Partial Setoid" may help there. Alternatively, you can have the
uniqueness property as hypothesis in every theorem / lemma :-)
As for induction-recursion, I know of Agda and Lego that support it;
none of these is currently to the stage of practically useful as a
proof assistant, though.
Lionel
- [Coq-Club] mutually inductive definition, Robert Dockins
- Re: [Coq-Club] mutually inductive definition, Lionel Elie Mamane
- Re: [Coq-Club] mutually inductive definition, Frederic Blanqui
- Re: [Coq-Club] mutually inductive definition, Marino Miculan
