- To: Robert Dockins <robdockins AT fastmail.fm>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] mutually inductive definition
- Date: Tue, 8 Mar 2005 08:50:18 +0100
On 08/mar/05, at 03:02, Robert Dockins wrote:
I'm trying to define a type which has a uniqueness property. I thought
I'd define the type to be mutually inductive with a proposition type
indicating the uniqueness:
However, coq rejects the definition, complaining,
Error: The reference uniq_list was not found in the current environment.
well, I've raise this problem (with exactly this example) something like nine years ago; see
http://coq.inria.fr/pipermail/coq-club/1996/000065.html
for an analysis of the problem.
1) Why does this happen?
The short answer is: the CIC/pCIC type theory does not allow to define types whose sorts contain the types under definition.
This avoids possible loopholes which could lead to the inconsistency of the system.
2) Is there a better way to do what I want? Is it possible?
(I know I could just use ListSet, but I'm actually interested in a more
complex structure).
As far as I know, there is no way for defining directly this kind of types.
Of course, you can use well-formedness predicates, two-level encodings, etc., but I suppose that this is not what you (and me) want.
-marino
Marino Miculan - Department of Mathematics and Computing Science
University of Udine - via delle Scienze 206, 33100 Udine - Italy
vox: +39-043255-8486 - fax: +39-043255-8499 - mob: +39-3292606452
mail:miculan at dimi uniud it http://www.dimi.uniud.it/~miculan/
- [Coq-Club] mutually inductive definition, Robert Dockins
- Re: [Coq-Club] mutually inductive definition,
Lionel Elie Mamane
- Re: [Coq-Club] mutually inductive definition, Frederic Blanqui
- Re: [Coq-Club] mutually inductive definition, Marino Miculan
Lionel Elie Mamane
