- To: <coq-club AT pauillac.inria.fr>
- Subject: [Coq-Club] Generate a lemma from a former definition
- Date: Wed, 16 Mar 2005 17:24:50 +0100
Hi.
Let's assume I have such a definition :
Definition K2Diam (i:I) (j:J) : strucrule I J
((pdiam j (pcomma i (pvar 1) (pvar 2))),
(pcomma i (pvar 1) (pdiam j (pvar
2)))).
I want to write a function in ML allowing me to write in
coq :
add_lemma_rw K2Diam.
to automaticaly generate the lemma
Lemma K2DIAM_rw:forall decI decJ A W (t1 t2 : context I J
A W) (i:I) (j:J),
(apply_rule (K2Diam i j) decI decJ (TDiamond
j (Comma i t1 t2))) =
Some (Comma i t1 (TDiamond j
t2)).
(perhaps eventually also defining its proof
automaticaly)
quite like do add_morphism in setoid_replace (and like
what Antonia Balaa did in term_const with recursive_definition).
In order to do that, I wanted to get internal
representation of the definition and modify it according to a defined morphism,
to construct the lemma definition and declare it.
I tried using the function parse_vernac but that doesn't
really match with kind_of_term which seem to be the good object to use to do
such things.
Can you confirm kind_of_term is what I need to use
And then, tell me what function I can use to get the
kind_of_term representation ?
Yann Devisschere |
- [Coq-Club] Generate a lemma from a former definition, Devisschere Yann
- Re: [Coq-Club] Generate a lemma from a former definition, Claudio Sacerdoti Coen
- <Possible follow-ups>
