- From: Claudio Sacerdoti Coen <sacerdot AT cs.unibo.it>
- To: Devisschere Yann <devissch AT enseirb.fr>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Generate a lemma from a former definition
- Date: Wed, 16 Mar 2005 17:49:20 +0100
Dear Yann,
> add_lemma_rw K2Diam.
K2Diam is a qualified name (i.e. a name of the form A.B.C.l where A,B and C
are module names and l is a label).
You can use Nametab.locate to get a global_reference out of a
qualid. (A global_reference is a reference to a constant, or to an
inductive type or ...)
Then you check whether your global_reference is a ConstRef and you
extract the constant. (The constant is the type of the references to
constant definitions).
Global.lookup_constant gives you the constant_body of your constant.
(The constant_body holds the body and type of your definition).
Declarations.const_body and Declarations.const_type gives you respectively
the
body and types of your constants, that are respectively a
constr_substituted option (None for axioms) and a types (= constr).
Declarations.force gives you the constr out of the constr_substituted.
This is not the only way to do it. Other Coq developers may give you
different advices.
> Can you confirm kind_of_term is what I need to use ?
Yes.
Godd luck,
C.S.C.
Real name: Claudio Sacerdoti Coen
Doctor in Computer Science, University of Bologna
E-mail:
http://www.cs.unibo.it/~sacerdot
- [Coq-Club] Generate a lemma from a former definition, Devisschere Yann
- Re: [Coq-Club] Generate a lemma from a former definition, Claudio Sacerdoti Coen
- <Possible follow-ups>
