- To: robert dockins <robdockins AT fastmail.fm>
- Cc: Coq Club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] decidable eq on a well-specified type
- Date: Wed, 27 Apr 2005 16:07:30 +0200
This is an interesting problem. There is another simplified version: how to
prove the floowing lemma?
Lemma single_eq_proof : forall (A : Type) (x : A) (p1 p2 : x = x), p1 = p2.
Quoting robert dockins
<robdockins AT fastmail.fm>:
> I'm playing around with well-specified types and tried to prove
> something like the following :
> Parameter limit:nat.
> Definition nat_subset := { n:nat | n < limit }.
> Lemma eq_nat_subset_dec : forall x y:nat_subset, {x=y}+{x<>y}.
> I've had great difficulties, however. The problem comes down to showing
> that two proofs of (x<limit) are equivalent. From the definition of
> 'le' it seems pretty clear that this is the case. However I run into
> problems with second-order unification and the restrictions between the
> Prop and Set universes with all the techniques I have tried. Is it
> possible to prove a goal like this one without resorting to classic (and
> hence proof irrelevance)?
> Bug reports: http://coq.inria.fr/bin/coq-bugs
> Archives: http://pauillac.inria.fr/pipermail/coq-club
> http://pauillac.inria.fr/bin/wilma/coq-club
> Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
envoyé via Webmail/IMAG !
- [Coq-Club] decidable eq on a well-specified type, robert dockins
- Re: [Coq-Club] decidable eq on a well-specified type, Haixing Hu
- Re: [Coq-Club] decidable eq on a well-specified type, Benjamin Werner
- Message not available
- Re: [Coq-Club] decidable eq on a well-specified type, robert dockins
robert dockins
- Re: [Coq-Club] decidable eq on a well-specified type, Pierre Letouzey
