- From: Pierre Courtieu <Pierre.Courtieu AT univ-orleans.fr>
- To: Pierre Casteran <pierre.casteran AT labri.fr>
- Cc: Serge Leblanc <serge.leblanc AT wanadoo.fr>, coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Beginnier question.
- Date: Sat, 21 May 2005 14:28:31 +0200
On 20 mai 2005, Pierre Casteran wrote:
> Selon Serge Leblanc
> <serge.leblanc AT wanadoo.fr>:
> > I am trying to prove the the following trivial goal. I don't reach it,
> > can you show me how to make?
> > Goal forall n m:Z, Zmin n m = Zmin m n.
> Hi,
> There is a solution (attached) (with some non-trivial feature : the
> caseEq tactic)
> Perhaps one can give a simpler solution ???
Hi,
You can use " functional induction Zmin z z' " in place of " caseEq (z ?=
z')%Z. ". When you want to consider the different branches of a
pattern matching (and induction) inside a function, functional induction
(and Functional Scheme) is useful:
Require Export ZArith.
Transparent Zmin.
Open Scope Z_scope.
Lemma Zcompare_Gt_Lt : forall z z', (z ?= z')= Gt -> (z' ?= z)= Lt.
Proof.
intros z z'; case (Zcompare_Gt_Lt_antisym z z');auto.
Qed.
Lemma Zcompare_Lt_Gt : forall z z', (z ?= z')= Lt -> (z' ?= z)= Gt.
Proof.
intros z z'; case (Zcompare_Gt_Lt_antisym z' z);auto.
Qed.
Goal forall z z', Zmin z z' = Zmin z' z.
intros z z';unfold Zmin.
functional induction Zmin z z'. (* does the same as caseEq here *)
rewrite (Zcompare_Eq_eq _ _ H_eq_).
case (z' ?= z')%Z;auto.
rewrite (Zcompare_Lt_Gt _ _ H_eq_);auto.
rewrite (Zcompare_Gt_Lt _ _ H_eq_);auto.
Save.
- [Coq-Club] Beginnier question., Serge Leblanc
- Re: [Coq-Club] Beginnier question.,
Pierre Casteran
- Re: [Coq-Club] Beginnier question., Pierre Courtieu
- Re: [Coq-Club] Beginnier question, Pierre Casteran
- Re: [Coq-Club] Beginnier question., Roland Zumkeller
Serge Leblanc
Pierre Casteran
- Re: [Coq-Club] Beginnier question., roconnor
Pierre Casteran
David Pichardie
- [Coq-Club] Rational numbers, Carlos.SIMPSON
Pierre Casteran
