- To: Coq Club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] Beginnier question.
- Date: Mon, 30 May 2005 10:22:54 -0400 (EDT)
On Mon, 23 May 2005, Pierre Casteran wrote:
> I think that it should be better to develop (in the module framework)
> a theory of ordered sets (with a compare function) and prove not only
> the commutativity of min but also associativity, the same for max, ...
I fully agree with this. I strongly encourage this sort of modular work.
To get the ball rolling I have developed a modular framework for min and
max given a decidable total order. A dualizing module functor is created,
and max and its theory is defined to the dual of min. This means all the
theory of min is reused in the theory of max.
Anyone is free to take this and add/improve upon it.
Russell O'Connor <http://r6.ca/>
``All talk about `theft,''' the general counsel of the American Graphophone
Company wrote, ``is the merest claptrap, for there exists no property in
ideas musical, literary or artistic, except as defined by statute.''(* Author Russell O'Connor *)
(** This file is Public Domain *)
Require Import utf8.
(** This module provides a basis for the theory of decidable orders.
(** Right now it defines min and max functions, and contains the
framework and some example theorems of min and max.
(** A decideable order is a total order that is decidable. Here is the
signature.
Module Type Sig.
Parameter A : Type.
Parameter le : A ⇒ A ⇒ Prop.
Infix "≤" := le : order_scope.
Open Scope order_scope.
Axiom le_refl : ∀ x, x ≤ x.
Axiom le_antisym : ∀ x y, x ≤ y ⇒ y ≤ x ⇒ x = y.
Axiom le_trans : ∀ x y z, x ≤ y ⇒ y ≤ z ⇒ x ≤ z.
Axiom le_total : ∀ x y, {x ≤ y} + {y ≤ x}.
Parameter le_dec : ∀ x y, {x ≤ y} + {¬ x ≤ y}.
End Sig.
(** When the operands of ≤ are reversed, the result is the dual
decidable order. This functor module takes a decidable order to its
dual order. This is used to create dual theorems about min and max
for free.
Module Dual (Ord : Sig) <: Sig.
Definition A := Ord.A.
Definition le a b : Prop := Ord.le b a.
Definition le_refl := Ord.le_refl.
Lemma le_antisym : ∀ x y, x ≤ y ⇒ y ≤ x ⇒ x=y.
Proof.
unfold le.
set (H:=Ord.le_antisym).
auto.
Qed.
Lemma le_trans : ∀ x y z, x ≤ y ⇒ y ≤ z ⇒ x ≤ z.
Proof.
unfold le.
intuition.
apply Ord.le_trans with y; assumption.
Qed.
Lemma le_total : ∀ x y, {x ≤ y} + {y ≤ x}.
Proof.
unfold le.
set (H:=Ord.le_total).
auto.
Defined.
Definition le_dec : ∀ x y, {x ≤ y} + {¬x ≤ y}.
unfold le.
set (H:=Ord.le_dec).
auto.
Defined.
End Dual.
(** This module defines the min function, and some basic properties of min.
Module Min (Ord : Sig).
Import Ord.
Hint Resolve le_refl.
Hint Resolve le_antisym.
Definition min a b : A := if (le_dec a b) then a else b.
Lemma case_min : ∀ P : A ⇒ Type, ∀ x y, (x ≤ y ⇒ P x) ⇒ (y ≤ x
⇒ P y) ⇒ P (min x y).
Proof.
intros.
unfold min.
destruct (le_dec x y).
tauto.
destruct (le_total x y).
absurd (le x y); assumption.
tauto.
Qed.
Lemma min_glb : ∀ x y z, z ≤ x ⇒ z ≤ y ⇒ z ≤ min x y.
Proof.
intros.
apply case_min; tauto.
Qed.
Lemma min_left : ∀ x y, min x y ≤ x.
Proof.
intros.
apply case_min; auto.
Qed.
Lemma min_right : ∀ x y, min x y ≤ y.
Proof.
intros.
Qed.
Lemma min_sym : ∀ x y, min x y = min y x.
Proof.
intros.
do 2 apply case_min; auto.
Qed.
Lemma min_assoc : ∀ x y z, min (min x y) z = min x (min y z).
Proof.
intros.
set (H0 := le_trans x z y).
set (H1 := le_trans x y z).
set (H2 := le_trans z y x).
set (H3 := le_trans z x y).
repeat apply case_min; auto.
Qed.
End Min.
(** This module defines the max function as the dual of the min function.
All the theorems about min are dualized to produce theorems about max.
Module Max (Ord : Sig).
Import Ord.
Module DualOrd := Dual Ord.
Module Max := Min DualOrd.
Definition max := Max.min.
Definition case_max : ∀ P : A ⇒ Type, ∀ x y, (y ≤ x ⇒ P x) ⇒ (x
≤ y ⇒ P y) ⇒ P (max x y) := Max.case_min.
Definition max_lub : ∀ x y z, x ≤ z ⇒ y ≤ z ⇒ max x y ≤ z :=
Max.min_glb.
Definition max_left : ∀ x y, x ≤ (max x y) := Max.min_left.
Definition max_right : ∀ x y, y ≤ (max x y) := Max.min_right.
Definition max_sym : ∀ x y, max x y = max y x := Max.min_sym.
Definition max_assoc : ∀ x y z, max (max x y) z = max x (max y z) :=
Max.min_assoc .
End Max.
(** This module exports both the min and max theories.
Module MinMax (Ord : Sig).
Export Ord.
Module MinOrd := Min Ord.
Export MinOrd.
Module MaxOrd := Max Ord.
Export MaxOrd.
End MinMax.
(** This module defines half of the disributive laws between min and max.
Module DistributivityA (Ord : Sig).
Module MinMaxOrd := MinMax Ord.
Import MinMaxOrd.
Lemma min_max_distr : ∀ x y z, (min x (max y z))=(max (min x y) (min x z)).
Proof.
intros.
set (H:=le_antisym).
set (H0:=(le_trans x y z)).
set (H1:=(le_trans x z y)).
set (H2:=(le_trans z x y)).
set (H3:=(le_trans y x z)).
repeat apply case_min; repeat apply case_max; auto.
Qed.
End DistributivityA.
(** This module defines the other half of the distributive laws about min and
max.
These other laws are the duals of the previous distributive laws
Module DistributivityB (Ord : Sig).
Import MinMaxOrd.
Module DualDistrib := DistributivityA DualOrd.
Definition max_min_distr : ∀ x y z, (max x (min y z))=(min (max x y) (max x
z)) := DualDistrib.min_max_distr.
End DistributivityB.
(** This module combines the two modules about distributivity into one.
Module Distributivity (Ord : Sig).
Export MinMaxOrd.
Module DistributivityAOrd := DistributivityA Ord.
Export DistributivityAOrd.
Module DistributivityBOrd := DistributivityB Ord.
Export DistributivityBOrd.
End Distributivity.
(** This module combines all the modules about the theory of decidable orders
into one module.
Module Theory (Ord : Sig).
Module DistributivityOrd := Distributivity Ord.
Export DistributivityOrd.
End Theory.
(* -*- coding:utf-8 -* *)
(* v * The Coq Proof Assistant / The Coq Development Team *)
(* <O___,, * CNRS-Ecole Polytechnique-INRIA Futurs-Universite Paris Sud *)
(* \VV/ **************************************************************)
(* // * This file is distributed under the terms of the *)
(* * GNU Lesser General Public License Version 2.1 *)
(* Logic *)
Notation "∀ x , P" :=
(forall x , P) (at level 200, x ident) : type_scope.
Notation "∀ x y , P" :=
(forall x y , P) (at level 200, x ident, y ident) : type_scope.
Notation "∀ x y z , P" :=
(forall x y z , P) (at level 200, x ident, y ident, z ident) : type_scope.
Notation "∀ x y z u , P" :=
(forall x y z u , P) (at level 200, x ident, y ident, z ident, u ident) :
type_scope.
Notation "∀ x : t , P" :=
(forall x : t , P) (at level 200, x ident) : type_scope.
Notation "∀ x y : t , P" :=
(forall x y : t , P) (at level 200, x ident, y ident) : type_scope.
Notation "∀ x y z : t , P" :=
(forall x y z : t , P) (at level 200, x ident, y ident, z ident) :
type_scope.
Notation "∀ x y z u : t , P" :=
(forall x y z u : t , P) (at level 200, x ident, y ident, z ident, u ident)
: type_scope.
Notation "∃ x , P" := (exists x , P) (at level 200, x ident) : type_scope.
Notation "∃ x y, P" := (exists x , (exists y , P)) (at level 200, x ident)
: type_scope.
Notation "∃ x : t , P" := (exists x : t, P) (at level 200, x ident) :
type_scope.
Notation "∃ x y : t , P" := (exists x : t, (exists y : t, P)) (at level
Notation "x ∨ y" := (x \/ y) (at level 85, right associativity) :
type_scope.
Notation "x ∧ y" := (x /\ y) (at level 80, right associativity) :
type_scope.
Notation "x ⇒ y" := (x -> y) (at level 90, right associativity):
type_scope.
Notation "x ⇔ y" := (x <-> y) (at level 95, no associativity): type_scope.
Notation "¬ x" := (~x) (at level 75, right associativity) : type_scope.
Notation "x ≠ y" := (¬x=y) (at level 80, no associativity).
(* Abstraction *)
(* Not nice
Notation "'λ' x : T , y" := ([x:T] y) (at level 1, x,T,y at level 10).
Notation "'λ' x := T , y" := ([x:=T] y) (at level 1, x,T,y at level 10).
(* Arithmetic *)
Reserved Notation "x ≤ y" (at level 70, no associativity).
Reserved Notation "x ≥ y" (at level 70, no associativity).
(* test *)
Goal ∀ x, True -> (∃ y , x ≥ y + 1) ∨ x ≤ 0.
(* Integer Arithmetic *)
(* TODO
Notation "x ≤ y" := (Zle x y) (at level 1, y at level 10).
- [Coq-Club] Beginnier question., Serge Leblanc
- Re: [Coq-Club] Beginnier question.,
Pierre Casteran
- Re: [Coq-Club] Beginnier question., Pierre Courtieu
- Re: [Coq-Club] Beginnier question, Pierre Casteran
- Re: [Coq-Club] Beginnier question., Roland Zumkeller
Serge Leblanc
Pierre Casteran
- Re: [Coq-Club] Beginnier question., roconnor
Pierre Casteran
David Pichardie
- [Coq-Club] Rational numbers, Carlos.SIMPSON
Pierre Casteran
