- From: Pierre Casteran <pierre.casteran AT labri.fr>
- To: xiang sen <xiangsen AT ustc.edu>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] How to determine the parameters order in "apply" tactic
- Date: Sun, 3 Jul 2005 12:10:13 +0200
Selon xiang sen
<xiangsen AT ustc.edu>:
> Hi, all :
> When I apply a lemma on the current goal , there are many parameters
> required to be specified.
> But their order seems puzzling. What 's the mechanism of order
> determination in coq. Thanks!
Hi, Xiang,
Have you some examples of problems you encounter ?
In general, the order is the left-to-right order.
Nevertheles, some little problems can arise if you are working through a
notation which permutes this order :
Notation "x < y" := (my_module-gt y x) : my_scope.
You must consider that y is at the leftmost position, even if
"x < y" is displayed.
But this is not a big problem: In dubious situations, I use the
command Check or About to look at the names of the parameters, and
I use the (A:=t) feature (look at "apply with" and at "implicit parameters"
Cheers,
Pierre
> All the best!
> Xiang Sen
> Bug reports: http://coq.inria.fr/bin/coq-bugs
> Archives: http://pauillac.inria.fr/pipermail/coq-club
> http://pauillac.inria.fr/bin/wilma/coq-club
> Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
Pierre Casteran
http://www.labri.fr/Perso/~casteran/
(+33) 540006931
This message was sent using IMP, the Internet Messaging Program.
- [Coq-Club] How to determine the parameters order in "apply" tactic, xiang sen
- Re: [Coq-Club] How to determine the parameters order in "apply" tactic, Pierre Casteran
- <Possible follow-ups>
- Re: [Coq-Club] How to determine the parameters order in "apply" tactic, Yves Bertot
