- To: Pierre Casteran <pierre.casteran AT labri.fr>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] How to determine the parameters order in "apply" tactic
- Date: Sun, 03 Jul 2005 18:28:19 +0800
Pierre Casteran wrote:
Selon xiang senAn incomplete example, but it's enough.
<xiangsen AT ustc.edu>:
Hi, all :
When I apply a lemma on the current goal , there are many parameters
required to be specified.
But their order seems puzzling. What 's the mechanism of order
determination in coq. Thanks!
Axiom compose_MBlk_MBlk_MBlk: forall (h1 h2 h:heap) (rf :rfile) (siz1 siz2 :nat)
(pr1 lnk1 pr2 lnk2 : addr),
hdisj h1 h2 -> heap_eq (happend h1 h2) h ->
pr1 < pr2 -> pr2 = pr1 + siz1 ->
MBlk (pr1 + 2) lnk1 siz1 (h1,rf) ->
MBlk (pr2 + 2) lnk2 siz2 (h2,rf) ->
MBlk (pr1 + 2) lnk1 (hread' h1 (pr1 + 1) + hread' h2 (pr2 + 1))
(hwrite h (pr1 + 1) (hread' h1 (pr1 + 1) + hread' h2 (pr2 + 1)), rf).
Ltac mblk3 :=
match goal with
| [H1 : MBlk (?pr1 + 2) ?lnk1 ?siz1 (?h1, ?rf), H2 : MBlk _ ?lnk2 ?siz2 (?h2, ?rf)
|- MBlk (?pr1 + 2) ?lnk1 _ (_, ?rf)] =>
apply compose_MBlk_MBlk_MBlk with siz1 siz2 lnk2; auto
end.
As you see, the order is (siz2 lnk2) instead of (lnk2 siz2).
It the order is left-to -right, it should be (lnk2 siz2).
Best regards
Xiang Sen
Hi, Xiang,
Have you some examples of problems you encounter ?
In general, the order is the left-to-right order.
Nevertheles, some little problems can arise if you are working through a
notation which permutes this order :
Notation "x < y" := (my_module-gt y x) : my_scope.
You must consider that y is at the leftmost position, even if
"x < y" is displayed.
But this is not a big problem: In dubious situations, I use the
command Check or About to look at the names of the parameters, and
I use the (A:=t) feature (look at "apply with" and at "implicit parameters"
Cheers,
Pierre
All the best!
Xiang Sen
Bug reports: http://coq.inria.fr/bin/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
- [Coq-Club] How to determine the parameters order in "apply" tactic, xiang sen
- Re: [Coq-Club] How to determine the parameters order in "apply" tactic,
Pierre Casteran
- Re: [Coq-Club] How to determine the parameters order in "apply" tactic, xiang sen
- <Possible follow-ups>
- Re: [Coq-Club] How to determine the parameters order in "apply" tactic, Yves Bertot
Pierre Casteran
