coq-club - Re: [Coq-Club] loading paths in coqide
chronological Thread
  • From: Guillaume Melquiond <guillaume.melquiond AT ens-lyon.fr>
  • To: coq-club AT pauillac.inria.fr
  • Cc: anoun AT labri.fr
  • Subject: Re: [Coq-Club] loading paths in coqide
  • Date: Wed, 06 Jul 2005 13:35:27 +0200
Le mercredi 06 juillet 2005 à 12:57 +0200,
anoun AT labri.fr
 a écrit :
> Hi all,
> I have an application in Coq which is composed of several directories, I
> want to
> know how we can load all the paths of the different directories so that we
> will
> be able to export easily different files...
> For instance, if we assume that we have two directories der1 der2, where
> der1
> contains file1 and file2 and dir2 contains file3 which needs to export
> file1...
> Should we add in the beginning of all files the command 'Add LoadPath
> ".."?? Or
> is there a more elegant solution with the interface coqide?
Some of the command-line options of coqc work with coqide too. So you
can just use "coqide -I .." to set the path beforehand.
Regards,
Guillaume
