- From: Pierre Courtieu <Pierre.Courtieu AT univ-orleans.fr>
- To: Coq Club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] loading paths in coqide
- Date: Thu, 7 Jul 2005 10:52:58 +0200
On 06 jui 2005, Guillaume Melquiond wrote:
> Some of the command-line options of coqc work with coqide too. So you
> can just use "coqide -I .." to set the path beforehand.
-I is definitely what you need. Actually coqc works exactly like a
compiler: you need a line in your makefile like :
COQC=coqc -I . -I foo -I bar
It is recommended (I believe) that you have only one makefile at the
root of your development (and ou call it with make -C .. when you are in
subdirectories).
coqide and coqtop also accept the -I option. So after compiling
dependencies with make -C, then do coqtop -I <paths to dependencies>. For
example coqtop -I ../foo -I .. if you are in the bar directory.
If you use coqide, then call it directly with this options
coqide -I ../foo -I ..
If you use ProofGeneral the recommended way is to put file variables to
remember the coqtop options for each file. See pg manual
(http://zermelo.dcs.ed.ac.uk/userman) section "Using file variables".
Regards
- [Coq-Club] loading paths in coqide, anoun
- Re: [Coq-Club] loading paths in coqide,
Guillaume Melquiond
- Re: [Coq-Club] loading paths in coqide, Pierre Courtieu
Guillaume Melquiond
