coq-club - Re: [Coq-Club] What Set is good for?
chronological Thread
  • From: Benjamin Werner <benjamin.werner AT inria.fr>
  • To: Vladimir Voevodsky <vladimir AT ias.edu>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] What Set is good for?
  • Date: Thu, 21 Jul 2005 11:01:36 +0200
   Hello,
Le 20 juil. 05, à 16:30, Vladimir Voevodsky a écrit :
I am learning Coq and I can not understand why it needs the sort Set. As far as I can see Type can be used everywhere where Set is used.
You are basicaly right. Set can be considered as the lowest element of the Type(i) hierarchy. Originaly however, Set was impredicative, while Type (actually the hierarchy of Type(i)'s) is not. When it was decided to make Set predicative, there were two reasons for keeping Set:
* One is that it was decided to keep the possibility to run coq with the option "impredicative" and keeping the old behavior of Set. For that, it was easier to keep the entry Set in the system.
* The other one was for compatibility. Indeed, the tactics which chose names for hypotheses they introduce (like inversion) will chose different names whether the sort of this hypothesis is Set or Type. Therefore, if one maps all entries "Set" to "Type" in the existing developments, the naming behavior of these tactics is changed and one introduces a lot of stupid, but nether the less difficult to correct, mistakes.
It is clear that this second reason is circumstancial and not very satisfiying. However, it was decided that keeping an entry Set was the easiest compromise even if, as you point out, it introduces some confusion.
Another confusing point is that the closest analog of a "mathematical set" in Coq is a setoid (a type with an equality) while a member of Set is something, from my perspective, rather weird.
The choice of the keyword Set can certainly be discussed like most syntactic choices. As to what corresponds best to a set in a type-theoretical setting, this is a vast question whose issues have not yet been all setled.
Best wishes,
Benjamin
