- From: Stefan Karrmann <sk AT mathematik.uni-ulm.de>
- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] The type of 'fun i:nat=>Type(i)' [Was: What Set is good for?]
- Date: Sat, 23 Jul 2005 16:42:52 +0200
Benjamin Werner (Thu, Jul 21, 2005 at 11:01:36AM +0200):
> Le 20 juil. 05, à 16:30, Vladimir Voevodsky a écrit :
> >I am learning Coq and I can not understand why it needs the sort Set.
> >As far as I can see Type can be used everywhere where Set is used.
> You are basicaly right. Set can be considered as the lowest element of
> the Type(i) hierarchy. Originaly however, Set was impredicative, while
> Type (actually the hierarchy of Type(i)'s) is not. When it was decided
> to make Set predicative, there were two reasons for keeping Set:
If we use the index in the hierarchy of Typ(i)'s explicitly, we have
forall i j:nat, i < j -> Type(i):Type(j)
in Coq.
What is the type of 'fun i:nat => Type(i)' or 'Type' ???
Is it 'forall i:nat, Type(i+1)'?
But this is a tangled recursive definition of a value *and* its type.
Or is it something like 'Type omega' where omega is the smallest infinite
ordinal? But then Type must have type 'forall o:ord, Type(ord_succ o)' where:
Inductive ord:Set :=
| ord_zero : ord
| ord_succ : ord -> ord
| ord_limit : (nat -> ord) -> ord.
Fixpoint nat_to_ord (n:nat):ord :=
match n with
| 0 => ord_zero
| S m => ord_succ (nat_to_ord m)
end.
Coercion nat_to_ord : nat >-> ord.
Definition omega : ord := ord_limit nat_to_ord.
Note: The specification ord does belong to Set, although the collection of
ordinals is a proper class in the sense of Von Neumann-Bernays-Gödel
set theory (NBG)! This looks paradoxical.
Regards,
Stefan
- [Coq-Club] What Set is good for?, Vladimir Voevodsky
- Re: [Coq-Club] What Set is good for?, Bas Spitters
Benjamin Werner
- [Coq-Club] The type of 'fun i:nat=>Type(i)' [Was: What Set is good for?], Stefan Karrmann
- Re: [Coq-Club] The type of 'fun i:nat=>Type(i)' [Was: What Set is good for?], Vladimir Voevodsky
