coq-club - [Coq-Club] Universes Question
chronological Thread
  • To: coq-club AT pauillac.inria.fr
  • Subject: [Coq-Club] Universes Question
  • Date: Sat, 23 Jul 2005 12:27:38 -0400
Hello,
thank you very much for the answers to my question about Set. I'll have to think about it more but so far it confirms my feeling that I do not have to bother with Set while learning Coq. At least not at first.
Here is another question. As explained in Coq documentation Type is actually an hierarchy of types and a member of Type(i) is a type which was defined without mentioning Type(j) for j>=i. Fine. But what if I have a member of a low level type which is defined using higher order universes? For example declare a variable P:Type -> Prop. Let's assume it was declared as going from some Type(i). I do not care which one. Consider now a:Prop := ex P. Coq tells me that it is well defined. Hence, I have a member of Prop which is defined using higher universes. This feels wrong.
Vladimir.
