coq-club - Re: [Coq-Club] Mutually recursive functions
chronological Thread
  • From: Pierre Casteran <pierre.casteran AT labri.fr>
  • To: agnes gonnet <agnesgon AT hotmail.com>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Mutually recursive functions
  • Date: Mon, 22 Aug 2005 16:18:18 +0200
Hi, agnes,
I have some problems in understanding your example.
In particular, the role played by the parameter list_exp in the recursive call
to eval_op. It is not one of the constituents given by the destructuration of e
(the names of which are given in the error message).
Could you specify informally what should compute eval_exp and eval_op ?
Pierre
agnes gonnet wrote:
Hi,
could anyone explain me what is wrong with the following mutually recursive functions :
Inductive operation : Set :=
|OP2pt : operation
|OPany : operation.
Inductive exp : Set :=
|Espace : exp
|Emot : nat -> exp
|Eop : operation -> list exp -> exp.
Parameter env_extern : list nat.
Parameter list_exp : list exp.
Parameter Et : exp -> exp -> exp.
Parameter in_bool: (nat -> nat -> bool) -> nat -> list nat -> bool.
Fixpoint eval_exp  (e:exp) {struct e}: option exp  :=
match e with
 | Espace => Some Espace
 | Emot id => Some (Emot id)
 | Eop OP2pt (e1::e2::nil) =>
     match (eval_exp e1) with
     |Some(Emot id1) => match (eval_exp e2) with
                |Some (Emot id2) => if in_bool beq_nat id2 env_extern
              then Some Espace
              else None
    |_ => None
    end
      |_ => None
      end
 |Eop Opany (e1::e2::nil) =>  eval_op list_exp e2
 |_ => None
end
with eval_op  (l:list exp) (e:exp) {struct l} : option exp :=
  match l with
  |nil => Some (Espace)
  |e1::l1 => match (eval_exp (Eop OP2pt (e1::e::nil))) with
    |Some res => match (eval_op l1 e) with
           |Some res1 => Some (Et res res1)
           |None => None
           end
    |None => None
    end
   end.
Thanks.
Bug reports: http://coq.inria.fr/bin/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
         http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
