coq-club - Re: [Coq-Club] Mutually recursive functions
chronological Thread
  • From: Pierre Casteran <pierre.casteran AT labri.fr>
  • To: agnes gonnet <agnesgon AT hotmail.com>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Mutually recursive functions
  • Date: Tue, 23 Aug 2005 08:38:43 +0200
Hi, Agnès
If I undestand well your program, your evaluation function is parameterized by some
list of expressions (the list_exp parameter) , and the problem comes from you
use this parameter in recursive calls.
May I suggest to consider a main function eval_list whose structural_argument is
a list of expr, and having eval_exp as an auxiliary function ?
Something like that (perhaps does not fit your exact wish, but may be it's worth to
try this way ?)
Cheers,
Pierre
Require Import List.
Inductive exp : Set :=
|Espace : exp
|Emot : nat -> exp
|Eop : operation -> list exp -> exp.
Parameter env_extern : list nat.
Parameter list_exp : list exp.
Parameter Et : exp -> exp -> exp.
Parameter in_bool: (nat -> nat -> bool) -> nat -> list nat -> bool.
Require Import Coq.Arith.EqNat.
Fixpoint eval_list (l:list exp)(e:exp) {struct l}: option exp  :=
let eval_exp :=
(fix eval_exp (e:exp) : option exp :=
    match e with
| Espace => Some Espace
| Emot id => Some (Emot id)
| Eop OP2pt (e1::e2::nil) =>
    (match (eval_exp e1) with
    |Some(Emot id1) => (match (eval_exp e2) with
               |Some (Emot id2) => if in_bool beq_nat id2 env_extern
             then Some Espace
             else None
   |_ => None
                       end)
     |_ => None
  end)
  |Eop Opany (e1::e2::nil) => eval_list l e1
  | _ => None
  end)
 in
  match l with | nil => None
               | e'1::l1 => eval_list l1 (Et e'1 e)
          end.
agnes gonnet wrote:
Hi,
could anyone explain me what is wrong with the following mutually recursive functions :
Inductive operation : Set :=
|OP2pt : operation
|OPany : operation.
|Espace : exp
|Emot : nat -> exp
Fixpoint eval_exp  (e:exp) {struct e}: option exp  :=
match e with
 | Espace => Some Espace
 | Emot id => Some (Emot id)
 | Eop OP2pt (e1::e2::nil) =>
     |Some(Emot id1) => match (eval_exp e2) with
              then Some Espace
              else None
    |_ => None
    end
      |_ => None
      end
 |Eop Opany (e1::e2::nil) =>  eval_op list_exp e2
 |_ => None
end
with eval_op  (l:list exp) (e:exp) {struct l} : option exp :=
  match l with
  |nil => Some (Espace)
  |e1::l1 => match (eval_exp (Eop OP2pt (e1::e::nil))) with
    |Some res => match (eval_op l1 e) with
           |Some res1 => Some (Et res res1)
           |None => None
           end
    |None => None
    end
   end.
Thanks.
Bug reports: http://coq.inria.fr/bin/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
         http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
