coq-club - Re: [Coq-Club] prod list
chronological Thread
  • From: Venanzio Capretta <venanzio AT site.uottawa.ca>
  • To: vincent.chatel AT transport.alstom.com
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] prod list
  • Date: Thu, 06 Oct 2005 11:47:49 -0400
You can do this:
Inductive poly_list: Type :=
  poly_nil: poly_list
| poly_cons: forall X:Set, X -> poly_list -> poly_list.
Implicit Arguments poly_cons [X].
Check (poly_cons true (poly_cons 3 poly_nil)).
In the good old days when Set was impredicative you could have defined
it in Set instead of Types.
Cheers,
  Venanzio
On Thu, 2005-06-10 at 17:11 +0200,
wrote:
> Hi Coq'ers,
> I would like to construct an inductive type like prod but such that all
> elements of this type finish by a final element.
> ( ) : 1
> (a,( )) : A * 1 (it's isomorph to A)
> (b,a,( )) : B *A *1
> It seems like a list but in a list I cannot mix elements with differents
> types.
> Thaks in advance
> Vincent
