coq-club - [Coq-Club] R�f. : Re: [Coq-Club] prod list
chronological Thread
  • To: Venanzio Capretta <venanzio AT site.uottawa.ca>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: [Coq-Club] Réf. : Re: [Coq-Club] prod list
  • Date: Fri, 07 Oct 2005 09:38:12 +0200
Thanks, but in this case I cannot construct a poly_list of poly_list.
And when I assume that X : Type, I have a Universe Inconsistency
Regards
Vincent
You can do this:
Inductive poly_list: Type :=
  poly_nil: poly_list
| poly_cons: forall X:Set, X -> poly_list -> poly_list.
Implicit Arguments poly_cons [X].
Check (poly_cons true (poly_cons 3 poly_nil)).
In the good old days when Set was impredicative you could have defined
it in Set instead of Types.
Cheers,
  Venanzio
On Thu, 2005-06-10 at 17:11 +0200,
vincent.chatel AT transport.alstom.com
wrote:
> Hi Coq'ers,
> I would like to construct an inductive type like prod but such that all
> elements of this type finish by a final element.
> ( ) : 1
> (a,( )) : A * 1 (it's isomorph to A)
> (b,a,( )) : B *A *1
> It seems like a list but in a list I cannot mix elements with differents
> types.
> Thaks in advance
> Vincent
Bug reports: http://coq.inria.fr/bin/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
          http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
:._______________
CONFIDENTIALITE : Ce message et les éventuelles pièces attachées sont
confidentiels. Si vous n'êtes pas dans la liste des destinataires, veuillez
informer l'expéditeur immédiatement et ne pas divulguer le contenu à une
tierce personne, ne pas l'utiliser pour quelque raison que ce soit, ne pas
stocker ou copier l'information qu'il contient sur un quelconque support.
CONFIDENTIALITY : This  e-mail  and  any attachments are confidential and
may be privileged. If  you are not a named recipient, please notify the
sender immediately and do not disclose the contents to another person, use
it for any purpose or store or copy the information in any medium.
