coq-club - Re: [Coq-Club] Packaging new tactics?
chronological Thread
  • From: Pierre Courtieu <pierre.courtieu AT gmail.com>
  • To: Adam Chlipala <adamc AT cs.berkeley.edu>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Packaging new tactics?
  • Date: Fri, 7 Oct 2005 17:29:01 +0200
  • Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=beta; d=gmail.com; h=received:date:to:cc:subject:message-id:in-reply-to:references:x-mailer:mime-version:content-type:content-transfer-encoding:from; b=IaTHTcbDnQamYsx1R144ll1/+ds4jk/qUAWpe8Ru3+ZAjUyxJES2sEYoVUwEhSByVfp4gtea7v0lfsEVxJP611J/QVvv3KZut+J4vuDsejd5BmC2MxdjcfiWi+Y0s4RhNkykX3uMZ01qqedQhFxcCxBIVGC+fy4LXGG3GeaoQV0=
On Fri, 07 Oct 2005 07:17:29 -0700 Adam Chlipala
 wrote:
> I've managed to decipher the relevant parts of the Coq source code
> well enough to implement a new tactic in OCaml.  However, I had to
> modify the Makefile and basically make it "built-in" to use it.
> Is there a better way for me to do things so that I can distribute my
> tactic as a "plug-in"?
You should look at the documentation of the cokmktop tool, at the
"Building a toplevel extended with user tactics" section:
http://coq.inria.fr/doc/Reference-Manual015.html#toc77
The idea is that once you have compiled your files into cmo (resp. cmx),
you can build a new coqtop (resp. coqtop.opt) linked with this new cmo
(resp cmx). So you can distribute only your files, with a small
dedicated makefile which build the cmo/cmx (it must know where to
find coq source path, use the coq_makefile tool to build such a
makefile), and builds the new toplevel with cokmktop.
Cheers,
Pierre
