- From: Venanzio Capretta <venanzio AT site.uottawa.ca>
- To: vincent.chatel AT transport.alstom.com
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Réf. : Re: [Coq-Club] prod list
- Date: Fri, 07 Oct 2005 11:37:51 -0400
On Fri, 2005-07-10 at 09:38 +0200,
wrote:
> Thanks, but in this case I cannot construct a poly_list of poly_list.
> And when I assume that X : Type, I have a Universe Inconsistency
You need impredicativity for both these things. If you launch coq with
the -impredicative-set option (for example "coqide -impredicative-set"),
then you can do this:
Inductive poly_list: Set :=
poly_nil: poly_list
| poly_cons: forall X:Set, X -> poly_list -> poly_list.
Implicit Arguments poly_cons [X].
Definition pl:=(poly_cons true (poly_cons 3 poly_nil)).
Check (poly_cons pl pl).
Cheers,
Venanzio
- [Coq-Club] Réf. : Re: [Coq-Club] prod list, vincent . chatel
- [Coq-Club] Re: [Coq-Club] Réf. : Re: [Coq-Club] prod list,
Benjamin Werner
- Re: [Coq-Club] Re: [Coq-Club] Réf. : Re: [Coq-Club] prod list, jean-francois . monin
- Re: [Coq-Club] Réf. : Re: [Coq-Club] prod list, Venanzio Capretta
Benjamin Werner
