- From: Claudio Sacerdoti Coen <sacerdot AT cs.unibo.it>
- To: mulhern <mulhern AT gmail.com>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Measuring the size of proofs
- Date: Mon, 24 Oct 2005 10:14:05 +0200
Hi,
> If the (number of XML markup characters / number of proof data characters)
> ratio is a constant
just a couple of observations on this:
1. counting the number of characters also means counting space characters
used for the indentation. It is better to count the number of
XML elements, i.e. it is better to add to the number of ">" characters
the number of "/>" characters. Each XML element corresponds to one
constructor in the data type used to represent terms internally.
(Of course, you are neglecting the fact that different constructors
require a different number of bytes in memory, but I think that this
is not your point, right?)
2. the internal representation of Coq tries to share as much as possible
the terms (and thus also the proofs). For instance, all occurrences
of (Rel 1) (i.e. every occurrence of the last bound variable) are
actually shared in the internal representation. That means that a
Coq's term is really a DAG and not a tree. On the contraty the XML
representation is really tree-like and purpousely destroys the
internal sharing. Once again, it is up to you to decide what do you
want to measure.
Regards,
C.S.C.
Real name: Claudio Sacerdoti Coen
Doctor in Computer Science, University of Bologna
E-mail:
http://www.cs.unibo.it/~sacerdot
- [Coq-Club] Measuring the size of proofs, mulhern
- Re: [Coq-Club] Measuring the size of proofs, Claudio Sacerdoti Coen
